mercuiser dipstick
recoil
hi guy does any one no were i can get a mercuiser dipstick from ?
Jethros
Re: mercuiser dipstick
you can make one to duplicate what you have if you still have the old one
recoil
i no longer have the old one
Jethros
You can search that motor for specs on oil capacity. Then pump or drain out the oil, fill with the correct amount of oil back into it, Then you will have the height of oil right there. Get a replacement oil dip stick at your favorite auto place. Dip into the hole all the way (if possible) When you pull it out you will have your correct height. Etching of indenting the high and low approximately 1" down from the oil height. Simple as that :cool:
