Merc's 4 Stroke 20 HP Carbed Motor.-
Sea Rider
Its on page 66 and should have the decal on cowl. Not rocket science, pump up bulb, pull choke. pump primer button 3 or 4 times and rip stater rope. Just like a chainsaw.
The motor doesn't have that decal on upper cowl or on any other place. Will try that starting procedure. Thanks.
Happy Boating
Sea Rider
So the correct startup procedure is as follows: Connect both fuel connectors sides fully in tank and motor. Open the tank's air vent if using a Standard non EPA fuel tank.
1-Prime bulb with arrow pointing up till firm. 2-Pull the manual choke 2 detent stops out. 3-Prime primer button 3-4 times. 4-Pull rope hard till motor starts. 5-Once started push choke knob in one detent stop. 6-Once warmed up, push the choke knob full in. 7-Gear F or R fom N and throttle to desired speed. Is this the first morning startup procedure ?
What about when the motor has cooled for say 2-3 full hours after running at speed. Must steps 1 to 6 be applied again ?
Happy Boating
