Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
What has been done up to date :
-Siphoned the old tank's fuel leftovers, added 20 Gals of 95 octane E8 fuel.
-Installed a new water separator filter at lower transom.
-Installed a new fuel filter and probe side to the VST.
-Removed heavily carbon build ups on all spark plugs threads.
-Cleaned and shinned all 6 spark plug's booth contacts.
-Installed 6 new NGK spark plugs gaped tight to 1.0 mm.
-Installed 2 new OEM thermostats & gaskets.
-Gear case flush with new oil along new oil change.
Special attention was given to both thermo's mating surfaces, took more than 4 hours with a Dremel tool, healing patience and small SS metal brushes to sand/polish both thermo's surfaces. Pics speaks for themselves...
Before...-Siphoned the old tank's fuel leftovers, added 20 Gals of 95 octane E8 fuel.
Thermo covers were so stone salted that completely lost their circular edged contours.
After..
Mr Dremel took care of the long tedious work polishing all the salted hardened deposits seen before, now both thermos will sit well their new gaskets on their perfectly cleaned round edges.
Thermo's upper blocks were found highly salted and rusted although both were flat sanded still looks flat rusted, this motor was never water flushed with fresh water before in its entire life, old thermostats account for such horrible salty scenario.
Just in case have added an even coat of Mega Gray with a thin brush at each thermos mating surface sides to avoid any possible pressurized water loss when at wot.
Would have liked to remove both thermo switches to clean their upper tips, but the available working space is very tight to deal with along fearing to break both upon removal. Wednesday morning is D Day..
Happy Boating
Happy Boating
