Conoloway Dave
Thread starter- Joined
- Jul 27, 2010
- 5
Year 1999, Model MCM 5.0L EFI, 305 CID..I have been dealing with this problem for 3 years now and need help. This is an intermittent issue whereby after running the boat for a couple hours on water and turning off, she sometimes fails to start back up. I can hear the fuel pump priming, and after removing the flame arrestor, I can see the fuel injectors spraying gas into throttle body (not a strong spay), the engine fires for about a second and then stalls out. After sitting sometimes up to 2 hours, it starts up. Once it starts, I'm golden with no hesitations at idle, full throttle, etc...... It only happens after I turn it off. I have taken this boat in a couple times but the mechanics can't get it to fail to determine the problem (no codes as well). I have been told so it's the fuel pump, fuel cooler, distributor, coil, ECM, bad ground wire, etc... I can't afford to throw parts at this problem. Any ideas?????
