jdubslopro
Thread starter- Joined
- Mar 5, 2010
- 91
I'm going to replace my manifolds and risers that only have a water inlet on the bottom of the manifold with a set that has water inlet on riser and manifold. Where does the water line connect from that goes to the manifold? From pictures I've determined that the riser is fed from the thermostat housing area (water manifold) but I can't tell where the line to the exhaust manifold goes. Should I just remove the water inlet from the riser and insert a pipe plug, and just run the manifolds in the same fashion as my current setup?
