Mercruiser I/O thermostate problems
glmtrophy2352
Was wondering if anyone was having problems or has heard of problems with mercruiser thermostates for 5.7 engines. I am on my fourth one and they all seem to go bad after one or two uses (engine run on muffs at idle)when first replaced they work fine no overheating but day or two later run the boat and it wants to run engine hot but manifolds are Ok temp. Am using heat gun to check and temps are getting to about 180-190 without thermostate opening (140degree) or am I missing something?
chewy7097h
Re: Mercruiser I/O thermostate problems
The thermostat controls the minimum operating temperature, not the maximum. You are overheating somewhere else - impeller, water pump?
Ayuh,.......
I gotta believe you have Issues, Other than a string of Bad T-stats......
I've Never heard of such a thing.....
Don't you have a Heat Gauge,..?? What's It say,..??
Don S
From your other posts, I gather this is all happening on muffs.
Back it down into real water and start it up and see what happens.
glmtrophy2352
Headed out to the lake Wed. AM. will post Wed Pm on how it turns out.
