Mercruiser gauges
oldsub86
How do I find out what a certain part # is intended for?
63780 A1 is the number - a gauge package for a Mercruiser but how do I tell if it is intended for a 4, 6, or 8 cylinder? Or - are they adjustable so that it should work with any # of cylinders?
Randy
Re: Mercruiser gauges
Ayuh,... Other than changing the setting on a tach,...
Gauges don't care how many cylinders are in a motor...
oldsub86
Yes, but is the tach adjustable? Many automotive tachs can be changed from 4 to 6 to 8 cylinders. Is the same true of the Mercruiser tach?
Randy
Alpheus
Yep. There is a rotary switch on the back of the tach to turn to whatever you got...
Howard Sterndrive
no - those 1960's merc gauge kits had to be ordered with the proper tach
if I had to guess, A1 would be 4 cyl, A2 would be 6 cyl, and A3 would be 8 cyl tach... but that is a guess
if you have the tach - flip it over and look -it will be stamped # cyl
if you're shopping - ask the seller
oldsub86
Therein lies the problem. Seller has no idea. Cannot compare with my boat as it is about 200 miles away.
Randy
Howard Sterndrive
if the seller is not willing to flip it over and read it, shop elsewhere.... they're old parts, but not actually that rare.
oldsub86
I'm guessing he is just not knowledgable about things like this. I may have to go and have a look.
Randy
