mercruiser engine model???
bigchunkytaco
hi just trying to figure out which engine models i am running so i can source a manual if anyone is able to tell from the serial numbers?
they are twin mercruiser 260 inboard cooled with serial #6703143 and #A608492
sitting in a 30ft 80's model searay vanguard hooked up to v drives
this is the only picture i have at the moment..
achris
More fish than mountain goat
Re: mercruiser engine model???
I'll check it out in a week when I'm home. I'm currently through a proxy that is not allowing a connection... (Work interfering with play again :facepalm:)
Don S
The link works, just no preview or scan due to size of file. Just click the download button.
bigchunkytaco
much appreciated thank you!
is anybody aware of what these cannisters are in the exhaust pipes?
bigchunkytaco
so they are just mufflers? the port side cannister is rusted through and leaks out water, this engine is also overheating could this have anything to do with it? its hard to tell if the impellor is picking up enough water if its not all exiting the exhaust flaps...
Ayuh,.... Either fix it, replace it, or stuff a straight piece of pipe in there...
achris
Nope... My guess would be that the heat exchanger hasn't been cleaned out in a while. Start there and then have a look at the impeller.
Chris....
