FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
mercruiser has literally been putting GM 350's (5.7 liters) in boats for well over 55 years. you have to be a bit more specific. like exact year and we need the serial number.
over that time there have been 4 generations of 5.7 liter motors, and about 8-10 different carburetors used.
hello . the pin that's responsible for adding fuel sometimes stuck and rpm is maximum 3000 rpm. and the boat is not moving fast. i tried to fix it two times and everything is ok for just one week. and then problem appears again. so i have been adviced to buy new one. and by the way the gasket at the bottom leaks air.. thanks
Did you actually install a carb kit? And adjust the float height/drop? If all you are doing is cleaning it, it'll never be right without a new needle/seat. That bottom gasket is easily obtainable from your local parts store.
