HorizonblueDK
Thread starter- Joined
- May 27, 2010
- 355
A friend has a 2006 Campion Chase with a Mercruiser 5.0 MPI/Alpha One, approx 100 hours. Oil is running out, but we can't see where. After a few trips, the drive lube reservoir is empty.
I have pressure tested the outdrive(without oil, 9 psi), after 12 hours it has only lost 2-3 psi.
Oil is apparently only leaking when the engine is running/drive is in gear. When the boat is stored on the trailer at home, nothing is happening.
I have not made a thorough check of the engine compartment, but my friend tells me that there is no oil spill in there.
This oil loss is weird, has anyone experienced something similar before?
