Mercruiser Alpha 1 outdrive gen II trim problem
Ninjamedic
Hi,
New member here. I just bopught a 1998 Larsen 186 LXi BR with a 4.3 Mercruiser and Alpha 1 outdrive. I am having a problem with the power tilt/trim. The unit lowers with no problems and the up and down trim work appropriately while the boat is running. My problem is when using the trailer button, the drive only moves at the same speed as when being trimmed in the water (i.e. very slowly). It takes about 1 minute to raise the outdrive for trailering. Any suggestions would be greatly appreciated.
:confused:
Re: Mercruiser Alpha 1 outdrive gen II trim problem
Ayuh,... That's the way it Works...
