Mercruiser 888 fresh water pump
CEnsming1973
Hi all
I'm new to this boating stuff. I purchased a 73 sea ray from my brother. It has a 351W mated to a mercruiser 888 outdrive. I was just wondering if the boat has to be in forward for the pump to actually pull water into the engine. Curently when I put muffs on or put outdrive in 55 gal drum it dosnt pull any water into engine. (In neutral) My brother stated he had the same problem but when he's out on the water no problems. So I'm just confused on weather or not I have a problem or just not testing it correctly. I just dont want to get out in the water and overheat.
stonyloam
Re: Mercruiser 888 fresh water pump
It should pump any time the engine is running, whether in gear or not.
CEnsming1973
Thank you so I'm assuming the pump is bad. Thanks for the info.
kato14709
Have you replaced the impeller in the water pump in the lower unit?
haulnazz15
Sounds like the impeller/water pump in the outdrive needs to be replaced.
