Mercruiser 7.4 MPI 1998 stalls when cold start
Micke9000
Hi.
I have a Merc 7,4 MPI 1998 and my engine stalls everytime i do a cold start. It runs about 2-5 sec and then it?s just shut off. Stalls. But if i give throttle in the start i can sometimes get the engine to run, but if i back off the throttle the engine stalls.
If i let the engine start and stall one time, it starts and runs fine the second attempt
I have cleaned the IAC valve and change the fule filter with no effect.
Compression is fine.
Could it be the IAC anyway?
Oil pressure swith?
Anti-Siphon valve?
Kind regards
Micke
Re: Mercruiser 7.4 MPI 1998 stalls when cold start
most boats are temperamental when starting cold.
alldodge
Hi.
Oil pressure swith?
Anti-Siphon valve?
Kind regards
Micke
:welcome: to iboats Mickie
It could be the IAC but since if it dies once then it's fine is a puzzler.
Suggest checking the fuel pressure at the shrader valve on the fuel rail. Also check to see if your vacuum line is connected from the intake to the pressure regulator (Item 15).
http://www.mercruiserparts.com/Show_Pictures3.asp?dnbr=809994 98&ivar=images/COMMON/20147.png&inbr=2705&bnbr=110&bdesc=FUEL+PUMP+AND+FUEL+COOLER
Also, there are 2 relays on the engine, one is the main power relay and the other is for the fuel pump. Both relays are the same, swap them and see if anything changes (Item 27).
http://www.mercruiserparts.com/Show_Pictures3.asp?dnbr=809994 98&ivar=images/COMMON/35598.png&inbr=2705&bnbr=70&bdesc=ELECTRICAL+BRACKET+AND+COMPONENTS
dubs283
when was the last FULL tune-up??
Mischief Managed
M7 2000 7.4 MPI does that now and then too. No idea why. It runs perfectly otherwise. Seems more likely to do it after sitting for more than a week though.
Micke9000
What gauge and fitting do i need?
Regards
Micke
alldodge
Regards
Micke
Morning, You need a standard fuel pressure tester, one which works on fuel injected cars will work. The fitting is a shrader valve, which is like what you fine on the tires (valve stem)
