Mercruiser 6.2 Fuel System Fault Code
PremierPOWER
2018 Mercruiser 6.2L 300HP
Was pulling my 2018 Monterey 335SY out for the season last weekend and had a couple codes show up on the Vessel View. Anyone know off hand what this 902-5 code means? I know the 946-6 code is the stupid O2 sensors. I have spares to change them out, although the engines are still under warranty. I do have a Rinda scan tool if I need to further diagnose, but figured Id check to see if anyone has had this code before and what they found out.
alldodge
902
The PCM has had to add too much fuel trying to get the correct O2 reading.
The 902 code should clear when the O2 sensor is fixed
PremierPOWER
902
Awesome, thanks!!
Does Mercury have a list of all fault codes anywhere for the public?
alldodge
Don't think there is. Some time back I found a draft copy of the PCM 112 codes. Being draft it was just a start. Search for PCM 112 codes and you may find it still out there
