Mercruiser 5 alpha 1
Darlene777
Ayuh,..... Welcome Aboard,..... What vintage,..??
What have you done,..??
What's the back story on the boat,..??
It’s a 1988 v20 mercruiser alpha 1 I/O 1 owner just bought it Was well maintained out in water twice stuck twice water in gas then after we cleared it it wouldn’t come out of throttle into gear
Ayuh,..... Is the controller stuck in throttle only,..?? if so, fix the controller,...
Is the forward cable from the control to the shift plate by the motor workin',..??
Can you shift the drive with the lower shift cable removed from the shift plate, manually,..??
QBhoy
Sorry to ask...but are you pushing in the trigger to engage on the remotes
Darlene777
We could not get it into gear at all forward or reverse the shifter itself is old so maybe it needs to be replaced I’m starting to hate boata
