Hi guys, I have a 1989 Rinker Captiva 206 with a Mercruiser 5.7 (350). Took it out the first time, and the batteries weren't charging. After pulling the alternator, I discovered the power wire from the alternator to the batteries was broke at the eyelet. Replaced it. Now when running with muffs, I only get 12v at each battery, tested via my DVOM. Is there anything else I can check before I pull this alternator again and go have it tested, as it has two wires that would have to be cut, they're crimped, looks factory. Only two wires besides the power wire. Any help is appreciated.
Thanks
Brandon
Thanks
Brandon
