Mercruiser 470 Proponents - cylinder head question
missalot
I'm working on freshening up a 470. I need to replace the cylinder head. I have a few new Ford 460 heads left over from a truck project.
Has anyone installed the water outlet in the end of the head themselves? If so what did you do? I have thought about drilling and tapping for a pipe fitting, but my thought is the casting might be too thin and brittle to be successful.
Bt Doctur
Re: Mercruiser 470 Proponents - cylinder head question
red loctite, block of wood, drive it in
Bamaman1
I've got a 470 head with a fresh machine shop valve grind/rebuild.
I never got around to reassembling the engine after it dropped a thrust bearing bolt into the oil pan and partially seized. I also have the rest of engine parts, 1.64:1 Mercruiser 1 outdrive and a 23 pitch prop. I'd be glad to part the motor out if you need anything.
David @ 256-768-0599
missalot
Thanks all.
Bt Doctur, how did you make the hole in the end of the head, or were you referring to just replacing the fitting?
Thanks
