mercruiser 4.3 lx problem on shutoff
davidsp
hi little problem noticed on my new boat... when i run like normal then try to shutoff the engine using key off position
the motor is like keep running 2cylinder for 3 explosion then shutoff any idea?
achris
More fish than mountain goat
Re: mercruiser 4.3 lx problem on shutoff
It's called 'dieseling' or 'running on'... The only way to ensure it doesn't happen, is to let the engine cool off for a few minutes before turning the key off....
BTW... It's a bad thing! As the engine is trying to keep running, it can suck water back into the cylinders and hydrolock the engine...
Chris....
NHGuy
Also, check that your idle is nice and low. When warm you want 775 in neutral or 650-625 in gear. It should shut off well if cooled down and idled low.
davidsp
How many minutes before shut down i have to wait.. i wait 1min and its still apening... is it normal
achris
It could take as long as 4 or 5 minutes... You're trying to dissipate a 'heat soak' condition.
davidsp
Ok corect me if i wrong.. i need to wait 5minute before shutoff engine each time im gonna anchor?
achris
You could idle up to your anchor point... Use the time it takes to lay anchor to be your cool down period...
Ayuh,.... Usually, a Complete tune up, 'n carb adjustment will cure that dieselin' condition,...
Fastatv
What NHguy says. To reiterate, what is the idle speed when you shut it off? And, if your running hard, then coming off the plane, the engine can warm up a bit. Look at your gauge, whats the temp when you turn the key off.
davidsp
idle around 700 and temp around 65
Volphin
Could be that your timing is too far advanced. Bump it back 2-3 degrees and see if that helps.
achris
That idle speed is too high. You need it down to between 600 and 650 (and that is in neutral)...
Volphin
Ayuh, retardin' the timing will do that. ;)
modsrx
put higher octane gaz it will solved your problem ...not sure if u run regular gaz in it or ?? to mutch timing will make that problem and not enough octane will make the same problem ...u to choose how u want to solved the trouble
modsrx
and make sure that engine is not running very hot ....
