badboatowner
Thread starter- Joined
- May 9, 2010
- 4
Confused on where the water should be discharging from what I believe is called the "gimbal housing" ... running the motor with the rabbit ears on with a good flow the water predominately exits the starboard egress ... is that correct? The service tech over the phone says yes that is correct as you have a 4 cyl engine but I have no confidence ... my neighbor (small engine repair guy and a diy'er) says no it should be discharging equally (however, he has a 4.3 A1). I have an '06 with about 36 hours on it.
