Mercruiser 3.0 Losing Gear Oil
AllatoonaBayliner175
I’m losing gear oil rather quickly but the oil leak is plainly evident. I know there’s some seal and it could be leaking into the bellows but there is a hole above the water intake on the lower unit that some oil is coming out of. I’m just not sure what that means or what that hole is called.
achris
More fish than mountain goat
That's a drain hole. Most likely source of the oil is the shift Shaft Seal, but in that location it could be one of a couple of others too. You need to remove the drive, drain the oil and pressure test to confirm which seal..
Chris....
