Mercruiser 3.0 freeze plug locations
dyarumian
i bought an 86 mercruiser 140 hp with an alpha 1 stern drive. i found 2 places for the freeze plugs on the port side of the engine but it still leaks from somewhere in the back cant quite seem to find the source yet, is there another plug in the back of the engine or is something leaking?
speedholes
Re: Mercruiser 3.0 freeze plug locations
There is one behind the flywheel on the back. Pray it's not this one, as it means removing the motor, then taking the flywheel off. Start motor on muffs and see if water is leaking from the back, between the block and flywheel. That is the only other one I can think of right now.
Don S
Are you sure the water is coming from the engine and not the drive? A bad ujoint bellows would allow water into the boat from the transom shield. Has nothing to do with freeze plugs.
dyarumian
it could be that the boat has been sitting since 99 and it looks like allot of stuff is dry rotted. can i just call up a boat yard and have them order the part or maybe even get them to replace it?
uaw9fan
This time of year? You might see your boat back around october
dyarumian
yeah no kidding. so does anyone know whats involved doing it your self. will i have to pull the motor?
