Mercruiser 3.0 Alpha one gen1 backfires
vinny957
Was out on the lake for roughly 5 hrs had no problem with my boat on way back in boat backfired I shut down the motor to check out wat it was no obvious signs of a problem,
Now wen I try to start the bout it will not start and every 3 to 4 turn overs the boat backfires out exhaust. Just had carb rebuilt before backfire started
alldodge
Welcome
Start by doing a compression test
Most likely you have a burnt or warped valve
vinny957
Thank you I will do the test today and see the video below is what it's doing
  • 20230707_150105.mp4
alldodge
Do check the distributor to verify the hold down bolt is tight and it cannot be turned
