mercruiser 260 riser gasket recommendations
reefguy
I just got to taking off the old exhaust riser due to a crack, but after detaching from the manifold i noticed the gasket that
were in place ; the metal gasket which has no slots for any water circulation, i have attached a picture of the metal gasket, without the regular gaskets which were taken off in little pieces, if you look at the manifold it has slots and so does the riser, the original who had it done at the shop, could they have mistakenly put a metal gasket without the slots for water flow thru? pls take a look at the pics and see if, i should buy the metal with slots(if avail) or leave it, which im very sure will stop water flow thru and possible raise my temp. in the exhaust, pls correct if i am incorrect. thanks.
im having problems loading the other pics for you guys to see, so basically i wanted to know if those 3 slots in the manifold to the riser should be blocked with the metal gasket without the slots or it should have the slots in it.
thanks
alldodge
Re: mercruiser 260 riser gasket recommendations
Not knowing what your serial number is I'm working from a 1978-82 260. That would be for the most part yes These 3 pics should show what the installation is.
Gasket Exhaust Elbo 27-997772.jpgPlate Exhaust 60207.jpgMerc 260 Exhaust.jpg
There are two exhaust gaskets and one exhaust plate sandwiched between them
reefguy
why is the metal gasket there, is blocks the 3 water passages ways to the riser and after time it corrodes badly, was this intended for a particular purpose?
Bt Doctur
Like i said ,it all depends on the T housing and hose configuration.manifols can flow independant of riser flow.you need to tell us the engine serial number and type of cooling system.
reefguy
im still doing best on working on the serial number, the cooling system is just raw seawater pump..
reefguy
my manifolds and etc.. are in book #3, but the prints are so small and not so accurate, so i enlarge it makes it almost unreadable.
Bt Doctur
So you need a copy of #3 ?
reefguy
bt doc, yes i do need one.. but i am going to try to locate the starter and serial number.
reefguy
I found the serial number today, it wasn't difficult at all, just followed the main battery lead to the starter and there she was. Now i can order the necessary.. thanks alot guys.
bt doctur, question for you.. Are those pages out of the service manuals?
reefguy
any suggestions, which company is good to buy parts online?
alldodge
iboats is a good company
PondDonzi
Usually the closed plate means its for inboard/outboard, open plates are for inboard use, no stern drive.
reefguy
thanks for the info. guys..
I know they need to be installed with some type of gasket maker sealant, using regular
automotive high temp gasket sealant okay for this job?
