TheChosen1
- Aug 30, 2008
- 1
I have a 1989 Sea Ray 22DA with Mercruiser 5.7L that has a power steering problem. When I am at cruising speed everything works fine. When I am at idle the steering is stiff when turning right and noticeable harder when turning left. I have replaced the belt and lubed everything I can find. I tried to remove the steering cable where it connects to the control valve but I couldn't get it all the way out. I lubed what was exposed. Still having problem of stiff steering but only at idle or very low speeds. Why only when I'm at low speed and why harder to the left than right? Could it be the pump?
