and if it don't start, a compression test is a good start as to finding the health of the engine in question.
imho, even if it does start i'd still do a compression test to find the base health of the engine. certainly do that prior to making a decision as to rebuild, re-power, conversion.
fwiw, i had a toyota engine that wouldn't run. i couldn't find out why and was ready to scrap the whole truck. instead i went to a compression test to find the engine was healthy. it was something else that caused it not to run. it just took a long time to find the one wire that had chaffed through the wiring harness and wire insulation to grd that caused it not to run. after the compression test, i knew it was something pereffiale that was causing it not to run.
