mercruiser 170 rebuild repower or conversion
ryanwp87
Just pic led up a clean 73 sunchaser s 19 for a steal. Don't know if the motor run s yet. Being totally gutted for commercial trotlining and hoop netting. I respec t this forum. What should I do?
Ayuh,.... Welcome Aboard,.... I guess ya oughta look it over, hook it up, 'n see if it'll start, 'n run,....
thumpar
Do as Bondo stated. See if you can get it running and go from there. It could be it doesn't need anything.
ziggy
and if it don't start, a compression test is a good start as to finding the health of the engine in question.
imho, even if it does start i'd still do a compression test to find the base health of the engine. certainly do that prior to making a decision as to rebuild, re-power, conversion.
fwiw, i had a toyota engine that wouldn't run. i couldn't find out why and was ready to scrap the whole truck. instead i went to a compression test to find the engine was healthy. it was something else that caused it not to run. it just took a long time to find the one wire that had chaffed through the wiring harness and wire insulation to grd that caused it not to run. after the compression test, i knew it was something pereffiale that was causing it not to run.
