Mercruiser 165hp 250cid poor throtle response
regent 21
Hi all. I have just bought a 21' regent with a new 165 inline 6 Mercruiser with a new 2barrel Rochester carbie, new pointless distributor (don't know the brand), new starter,alt,etc. It starts and idles fantasticly as does it at constant revs (2000 or 3000rpm) the problem is geting there, as I throtle up, the eng runs poorly with very little power. The same problem at wide open throtle. Timing is set at 8deg BTDC at 600rpm vaccum advance is not connected. Does the timing need to be set at Hi revs? does it need a vaccum advance? Any thoughts or ideas appreciated.
ziggy
Re: Mercruiser 165hp 250cid poor throtle response
myself. i'd start with a compression test. see if ya got something to work with.
what is wot? should be between 3900-4300, leaning towards the higher number with your normal load and trim
timing is supposed to be 6* btdc. if it were my boat with points. i'd set dwell first to 31-34* then set timing to 6* btdc.
ya must have a auto distributor. marine distributors don't have vac. advance.
did ya R&R the fuel filter + clean the screen filter at the carb.
is the flame arrester clean.
if all is good and ya've checked the ign. side to be sure it's set proper. then i'd move over to the fuel system for issues. like does the accelerator pump on the carb work. like squirts some fuel into the carb with advancing of the throttle.
check out the adults only section. there's some trouble shooting hints in that thread.
check the oem s/m. there's trouble shooting guides there.
is the hull bottom clean.?
ya got the proper gear ratio on the drive. 1.65:1?
what pitch prop ya got? on my 19' i run a 19p aluminum.
i'm sure others will have some better ideas than me... i'm just joe boater... ;)
welcome to iboats...
new pointless distributor (don't know the brand), Timing is set at 8deg BTDC at 600rpm vaccum advance is not connected. Does the timing need to be set at Hi revs? does it need a vaccum advance?
Ayuh,... That's atleast part of yer Problem...
That's an Automotive distributer...
Boats don't run vacuum advance,....
They need the Proper mechanical advance....
You need a different distributer...
regent 21
Thankyou for your input. Have checked all the stuff mentioned and all OK. Having trouble locating a new distributor in Australia, looks like ill have to buy one in US and get it shiped over. Any ideas who to purchase from?
