Mercruiser 165 exhaust flapper
finisher88
I have installed a new Flapper in my exhaust pipe , can some look at it and tell me if it is installed the right way, Thx Hope I uploaded the pic okay.
achris
More fish than mountain goat
Re: Mercruiser 165 exhaust flapper
Looks good to me.....
165.... 4 cylinder or 6?
starsnstripers
Well done, Looks just like mine when i did it! ;) My only question would be that, I dont know if the teflon on those nuts will handle the exhaust heat? It may melt it and nuts come loose. I rivited mine like the factory did. Although i guess if the rubber can handle the heat i suppose the tflon nuts can. If i used nuts i may have double nutted regular nuts maybe. But yes it's in right.
finisher88
Thx for the input guys, it is from a 6 cylinder 165, I am doing a rebuild on the engine. This was a fresh water part that I blasted and painted. Good point on the lock nuts but I think they will be alright I also used lock tight. But I will have to think about it before I install it. I could not find any stainless pop rivets.
abj87
Exhaust/water mix hardly gets above 200 degrees. Mine i can stick my hand in the flow comfortably.
Shrub88
Where did you buy that flapper from?
I need one that looks just like it.
Boat is a Checkmate with thru-transom exhaust and one of them is burned up.
The pipes are 3" and the inside diameter is about 2 1/2".
Thanks.
finisher88
I got mine from the local Mercury dealer, they are not expensive, the nuts and bolts from Home depot
Shrub88
Thanks for the reply.
I have since found our boats take different shutters and will post my question in another thread.
