Mercruiser 140 with Delco EST ignition system
padn
I have replaced my old Mercruiser 140 with a GM Vortec Marine engine with Delco EST ignition system.
My questions are:
Do I have to remove the resistance wire to the ignition coil to increase voltage on coil ?
The shift interrupter switch in the 140 configuration is grounding the coil while shifting - it seems to me that the instead of grounding, the Delco EST distributor requires +12V while shifting - which means that i have to move the ground on the starter solenoid bracket to +12V - am i right or wrong ?
If anybody has a before and after wiring diagram I would appreciate that.
br
Peer
padn
Re: Mercruiser 140 with Delco EST ignition system
Thanks a lot - just what I needed. :)
