mercruiser 120 Throttle control
KIckashin
the neutral button on the controller is sticking. I took it apart this contoler has two cast wheels in side neutral has I pin with spring that sits in hole. it is very thin pin. I need to find any info on this type of throttle. picture diagram after removing the two cast wheel apart I can figure out how to line up the two wheels properly.
