Mercruiser 120 Oil Change Modification!
madmans
Anyone have a remote oil filter setup on a mercruiser 120 ? Or better ideas for changing the oil filters in them? Also does anyone ever use a flushing agent to try to clean out the oil pan sediments? Thanx Mike
Re: Mercruiser 120 Oil Change Modification!
Ayuh,... Welcome Aboard,...
It's easy to get to on the side of the motor, just loosen it, slip a plastic bag 'round it, 'n Spin it off....
As for Flushin',... Ya, 'bout 5 quarts of Fresh Oil is what I use.... ;)
madmans
Thanx I appreciate the reply. I was thinking for oil changes a remote type filter arrangement may of had some merits? Thanx Mike
Don S
Only if you can't get to the original filter does the remote make sense. On most 3.0L engines, finding a place to put a remote filter is more of a problem.
madmans
Thanx Don makes sense, I was after a way of thouroughly flushing out the lower pan oil, thinking a remote unit would enable me to hook up something for flushing out the Crancase, Like a small pump to flush some type solvent through the engine for thourough cleaning, SINCE the oil pan drains hard to get at. I appreciate youre time replying thankyou Mike
