Mercontrol rebuild
Status
Not open for further replies.
compfast
Can someone tell me where I can get rebuild kit, and an ignition switch and a choke switch for this mercontrol, that came with this motor: 1970 650 Merc 4 cyl 65hp...serial # : 280-5901
Unarmed
Re: Mercontrol rebuild
I have the same motor and control unit as you. to my knowledge there arn't any rebuild kits. if I were you I would browse ebay and craigslist for a replacement.
diaric
there are parts available. sierra has throttle cams and ignition switch's, but your asking for every part. better to look for a good replacement. what exactly is the trouble your having?
compfast
The control has alot of play in it, and someone told me the the cams or some other small part is probaly worn out, and I was just going to change the ignition and choke while i was in there..............and my wiring harness is fried.................thanks for theinfo guys :)...............do people sell a replacment control with the wiring harness already attached?...............................
Can you guys tell me where to find craigslist? and I can't find anything on sierra's site(not sure i found the right site?),
It would be awesome to buy a whole control with wiring harness
compfast
Cool, thanks man:)...............that makes sense that it's the throttle cam, because it shifts fine.
diaric
when my throttle cam was worn, it would go about half way up before the throttle increased, but on the way down, it idled down to about a quarter throttle. sometimes if its just sloppy, it can be a simple cable adjustment. should be a slight bit of preload from the cable
diaric
if you change the wiring harness, it might be a good idea to change the ignition switch with it. when you open it up, you'll see how tricky some of them are to resolder
compfast
Thanks for the help:)............will one of the newer non OEM ignition switches fit on this control, with little screws like this one (no solder )........
I am thinking the first one will work?........any idea if it will work with my control? :)
http://www.iboats.com/3_Position_Push_To_Choke_Mercury_Ignition_Switch/dm/**********.780130102--*******.392277456--category_id.216622--list_time.1183317544--view_id.39663
or this one?
http://www.iboats.com/Sierra_Ignition_Switch/dm/**********.780130102--*******.392277456--category_id.216622--list_time.1183317544--view_id.47122
diaric
i believe they both would work. they are designed for the newer controllers that have the choke operate by pushing in the key. I'm partial to the seperate choke button, but thats what i'm used to.
dchris
I opened my unit, which is the same as yours a couple of week ago. A good clean up and new grease made a big diference. New cables were the real key. It works smooth now.
ricksrster
The top picture looks like it might be too long to fit in the box. The bottom picture looks smaller.
compfast
compfast
Thanks , but when i click 414-2770 I get this............
and it looks nothing like what I need?....I need an external wiring harness............the one i have looks like ..18-5511 ? :).......is the photo wrong on iboats, and it is the right one??
http://www.iboats.com/414_2770_Internal_Engine_Harnesses/dm/category_id.271561--*******.392277456--**********.235729656--view_id.335997
and does anone know the OEM part number for my harness?......................someone else on this forum gave the same number (414-2770) and on a different site the photo of the harness matched what I have , but on I boats it doesn't look like my harness at all? :)
diaric
i'm not sure. your right that one is internal. your oem no. for the internal harness should be 52771A2. but i don't know what the external one should be.
it might take a phone call to clarify things as you need the picture to show you the connector pins so you can compare to yours.
compfast
Hey, thanks alot guys yall have
been alot of help :D
I decided to go with this one because it has the insulation covering all the wires the cheapers ones were all exposed
http://www.iboats.com/18_5511_Wiring_Harness/dm/category_id.271561--*******.865170705--**********.375684499--view_id.174724
and this ignition switch
Thanks again :D
Status
