Mercathode on a 3.0/Alpha?
E22
I keep my boat slipped in saltwater and most years need to replace anodes about 2/3 of the way through the 6 month season we get in the northeast. Thinking about installing a mercathode system but don't see much info out there for use on 3.0/Alpha (gen 2) drive systems. Is it even possible? Is it worthwhile? Looking for opinions. Thanks.
alldodge
Your drive needs all the help it can have fending off the galvanic corrosion. The MC will produce a opposing field current to reduce GC. Now if you boat is not plugged into shore power then I wouldn't bother, but if it is I would
E22
No shore power so will stay with religiously checking anodes.
Scott06
Do you have corrosion issues currently ? If not I’d stay with what you got. Mercathode is easy enough to add and doesn’t cost much $200 or so
tpenfield
You are still going to need the anodes in salt water. Install the Mercathode, if you like, but plan on doing the anodes anyway.
