Merc wiring
KPKID
Just bought a 14 ft '66 Steury with a '71 Mercury motor. All wires to ignition and lites and instruments have been cut. Any suggestions in rewiring. I would settle for just running lites and fuel gauge?
Also, has anyone had any experience in using opti-2 as fuel mix?
KPKID
1971 merc 400 wiring
I have lost power from the mercontrol to the choke. Any suggestions? It worked last week.
fwmud
Re: Merc wiring
I'd suggest going to your local boating store and buying the proper book on your Merc.
I have one and it's very detailed on all aspects of the motor including wiring.
achris
More fish than mountain goat
Re: Merc wiring
You are going to need the serial number of the engine to get the right book.
Re: Merc wiring
KPKID, Lights are wired directly to the battery, via a fuse. They do not go thru the MerControl. The gauges are run off the white ignition wire, off a 3 prong connector on the MerControl.
KPKID
Re: Merc wiring
thanks for the info.
