Merc wiring diagram...what is this symbol??
Drindin
I have this wiring diagram and seems straightforward...but I have no idea what the symbol, I've marked in red, is? Is it just a stray mark or something pertinent?
Drindin
Re: Merc wiring diagram...what is this symbol??
Laddies, I always appreciate your fast responses....A junction? Ok. Now, I guess I'm not seeing where wires come together. Further back on the salmon colored wire, there IS a split or splice. Could this be the junction you are referring to? Maybe the symbol was put in the wrong place?? I'm still not following you 100%.
Drindin
Or would it be the block...wait...duh. The junction block where everything comes together near the switch box, huh?
Laddies
Banned
It's shown that way because the tilt switch is not a permanent part of the harness and can be removed and replaced separately, the joint is probably the wire splice your talking about I believe the originally it was a junction block with a screw in it as shown.
Drindin
Thank you, Laddies.
