wharfcreek
Thread starter- Joined
- Jul 31, 2009
- 36
I have a 2000 Key West 1520 with a 60 HP Merc 4-stroke (recently replaced from a 50 Merc 2-stroke). It still has the original controls on the center console. I believe the shift cable is starting to crap out, as the force of having to shift is ripping the control right off the console. In attempting some temporary repairs, I'm about to replace the rubber expansion nuts used with some conventional nut/bolt combinations and a good flat washer underneath. Will be using some anti-seize compound as well. But, I had also thought I might attempt to remove and lubricate the cables to see if this helps. Unfortunately, I can't find any good info on my control. I can find all kinds of info on the 'side-mount' outboard controls, but nothing on my top mount set-up. Mine has the chrome plated plastic cover, the black button in the center of the throttle/shift lever that locks out the shift, and a rocker-switch on the side of the throttle handle for tilt/trim. Hopefully someone can come up with something that will give me a clue as to where to start. I have the whole assembly pulled up from the console, but cables and wires still attached. Any help would be appreciated. Many thanks!! Tom D.
