merc mr1 gear oil leak
larry310
i have a 1985 wellcraft with a 350 merc 260 hp i have a lower end leak of gear oil coming out of water drail hole on bottom right hand side of drive what will cause this ? i have tore lower end off 3 times this week can not find anything wrong o ring is in place please let me know at mnunnari1@roadrunner.com thanks
Bt Doctur
Re: merc mr1 gear oil leak
upper driveshaft seal leaking oil down the driveshaft
shift shaft seal
water pump base seals
