Merc Jetdrive
Gcompo
I am considering a 13' RIB with 95 Merc Jet drive (1998). The seller has told me it smokes a bit at start-up...I can live with that. Is the Merc Jet something I should avoid and keep looking for an outboard version?
thanks..
CharlieB
Re: Merc Jetdrive
Jets and outboards use the same engines, the difference is the drives, a jet pump instead of a gearcase and prop.
Depending on how you intend to use the boat is the best factor in determining your requirements.
Jets aren't near as efficient as a prop, BUT.........
you will grind a prop down in a hurry trying to run in shallow water.
