Merc 90 Cooling Question
CharlieZulu
Hi Folks:
Late '80s Merc 90, oil injected. My water flow starts right from the get-go..... does this mean my thermostat is stuck open, or is this normal? If it isn't normal, typically how long does it take for water to flow from a cold start?
electricjohn
Re: Merc 90 Cooling Question
Mine has always flowed fast from start up, and faster up to WOT. A gage threaded into my head shows 7 psi at idle, and 14 at WOT. The water never gets hot, but an infra red thermometer shows my heads at around 140 to 145*F when engine is at normal operating temps.
Hottip
The water from the telltale should start flowing as soon as the motor starts to turn over.
M
Maxz695
Guest
I believe the is a bypass that allows water to flo even if the thermostat is closed.
Charlie, Depending on the model of that motor, you may not have a thermostat. Most/all inline sixes didn't have thermostats..... Telltale water flow was after a few seconds
Faztbullet
Thats a 3 cylinder 90 and it has a t-stat and poppet valve. The tattle tale is fed off the exhaust plate before the t-stat so it will pee within 10-20 seconds of engine start.
M
Maxz695
Guest
mine runs off the exhaust plate does that mean the thermostat has nothing to do with the tattle tail?
CharlieZulu
Yes indeed, it's a 3-cyl.
Thanks, guys for the great info.
