I have an old Glastron with Mercruiser 888 freshwater lake boat. At the end of season started running hot, took it out early. was not rubber impeller on outdrive shaft. But what I did notice was a rubber hose inside gimbal that ran from above highest rubber boot to spot on lower unit, that was totally crimped [ no water flow].
My two questions are 1. is this a moulded rubber hose?
2. and can this be replaced by raising outdrive fully?
whitout having to pull pins, and disassemble gimble!
Thanks for any help
Thanks for any help
