Mike Newransky
- Jun 10, 2011
- 3
New member. I just pulled out my bearing carrier and prop shaft out of my lower unit to replace the seals. The shift cam follower (small rod, pointed at the end that rides against the shift cam) dropped out as I removed the assembly from the case. This is my question, should there be a spring behind the rod? I'm wondering if there was one and I lost it when the rod dropped out. Thanks for reading and if any of you with experience in this area could help I'd appreciate it.
Mike
Mike
