Greg New Zealand
Thread starter- Joined
- Dec 7, 2003
- 98
My 4 cyl '77 merc 50 is pull start. Always starts up OK but after being turned off (even 5 mins) I need to pump the primer up again to start it. Sometimes, if I just idle after a re start, it will die. If I give it some revs straight away it will be fine. Is this a check valve problem or fuel pump diaphragm? <br /><br />The motor is a real sweetie- will run WOT all day with no problems - it's only the stop/start thing that bugs me. Any suggestions will be appreciated.<br /><br />Greg
