Merc 500 - Can I add a tach?
GA_Boater
I have a 1966 Merc 500 - 50hp S/N 2012023 with Kiekhaefer magneto ignition. Can a tach be hooked up to one of the stator leads? I know its a 12 pole stator. Am I all wet? I've searched the forums but ho luck so far. Thanks.
merc850
Re: Merc 500 - Can I add a tach?
Yes an aftermarket unit or go for the best - a Mercury tach. Sometimes dealers will have used ones cheap, I've been using an old Merc tach for 20 years on 2 different engines.
GA_Boater
Thanks merc. Am I right that the tach signal is from the stator? I have no switchbox.
merc850
Yes you hook the sender terminal of the tach to either one of the yellow stator leads, NOT the red one.
GA_Boater
Thanks again, merc. Red is +12 = tach death. LOL
