bronko69er
Thread starter- Joined
- Jul 28, 2015
- 26
Greetings everyone, first time poster but not new to wrenching or tech forums. I've searched quite a bit but have still not convinced myself that I know the source of the problem. Boat in question is a 1980 Formula Thunderbird and has the 305 merc with the alpha one outdrive. The problem started to come on last season and seems to have gotten progressively worse since then. I noticed it first after the engine warms up (symptoms don't exist when cold) and after idling for a bit (like trying to teach a new skier or coming in and out of no wake zones). After idling for a minute or 2 the motor will die. I can get it to fire back up and rev it in neutral without much trouble, but it continues to struggle to stay lit at idle. It will also die if I try to put it in gear. The only way I can get going is to rev it, then put it into gear and get off idle quickly before it dies. Once it's off idle, it will stay running but can't get above 1500rpm or so no matter how much or little throttle I give it. It runs rough like a few cylinders are dead. During this rough running, I can sometimes coax it back to health by very slowly giving it throttle, If I give it too much throttle too fast it will start sputtering again. Sometimes this technique doesn't work at all, I'll keep modulating the throttle for several minutes when all of the sudden its like a switch is flipped and its back to normal.
In my research, I came across a lot of info on vapor locking, so I experimented with both leaving the blower running constantly, and leaving the top hatch open to let all the heat escape. Doing these things didn't seem to change the bad behavior.
-Maintenance to note: Plugs have only one season on them, wires, cap and rotor have 2-3 seasons, fuel filter is brand new (only 1 tank run through), winter storage gas (stabilizer added) is virtually burn through now, I ran it down to 1/8 and refilled with fresh, problem still exists.
-Things i've eliminated: Ignition interrupt switch (for getting into neutral). This gave me troubles when I first bought the boat but I have since adjusted it to proper functionality. Maybe vapor lock as it seems to behave the same in 70deg weather with the hatch open as it did in 85deg weather with a hot engine compartment.
-One other symptom I just noticed last night for the first time that is likely unrelated: Heading back in for the night, I coaxed it up to a happy 3500rmp and cruised across the lake heading back to the dock (10 min transit). After idling through the no wake zone, it died a few feet from the dock. When I tried to restart, it would barely crank. I have not investigated any further, but I think this is just my alternator going bad and not related to the other symptoms (but for the sake of full disclosure, I figured I'd include it). Battery is only 2 years old.
I also ran across threads about ignition modules under the dizzy cap going bad and having hot start issues, but I'm not convinced my symptoms suggest that.
Thanks in advance for any help with the troubleshooting, I've only got a week to solve this before a boat camping trip so I'd like to get after it quick.
