merc 3.o battery size
gnashin
What would be the best size battery for a 140 merc 3.o. cranking amps? Also how would I test a starter to make sure it is working properly? ? Thank you and safe boating
UncleWillie
Re: merc 3.o battery size
From another Post, long ago and far away....
Mercruiser 3.0L --- My owner's manual says "Minimum 375 cca/475 mca/90 Ah" ...
Most any Group 24 Battery will fit the bill.
Unless you have a specific reason to suspect otherwise; If the starter starts the Boat, it is working properly.
A simple Test.
Disable the ignition. Trip the Lanyard Kill Switch at the throttle.
Crank the engine for a full 10 seconds.
If the starter is cranking after 10 seconds without starting to slow down, The battery and starter can be assumed to be functional.
fishrdan
Group 24 will work just fine, but bigger is better in case you have engine start issues and need the extra power from a larger battery.
I used the exact same battery in my boat, that my V8 truck uses. In the event that the truck battery dies I can rob the boat, if the boat battery dies I can rob the truck. I had to use those funky brass automotive-marine terminal adapters, but they work fine.
(This is an automotive battery and not a "marine" battery, so I'm sure someone will comment on that....)
One bonus is that an automotive battery warranty is much better than a marine battery warranty.
