Merc 3.0 Fluxuating Voltmeter
chadz1
Every time I go to the Lake my voltmeter reads around 12 volts for the first approx 15 min. run time. Then it just jumps up to 14 volts and everything is fine. I confirmed it with my Fluke meter readings are the same. I keep the battery on a battery tender when not using the Boat.
Should I just buy an alternator or maybe have it rebuilt?
It has the Mando 55 amp alternator.
Thanks for any help
Fishermark
Re: Merc 3.0 Fluxuating Ammeter
Every time I go to the Lake my ammeter reads around 12 volts for the first approx 15 min. run time. Then it just jumps up to 14 volts and everything is fine.
I take it you mean "volt meter" - not ammeter. Some of the older boats do actually have ammeters.... but if yours is reading 12v it will be a volt meter.
Anyway - I would suggest taking the alternator off and having it checked. Sounds like the regulator may be sticking? :confused:
Is that at Idle, or at Speeds,..??..??
Ayuh,.... I'd Quit doing that,+ it'll be Just Fine......
chadz1
1.Yes thats at speeds.
2.OK Thanks.
