farscapehw
Thread starter- Joined
- Mar 17, 2009
- 12
i bought this 75' model mercury 200 with front of boat controls a year ago this month.
serial # 4148481
when i bought it it had a bad coil for the lower cylinder. it also had a fairly new switchbox on it.( november of 2004 punched out on the mfg date) i put a new coil on it and it ran like new for a few months. it started running bad missfiring and stuff. i ran it like that for a couple days because we were in the middle of a fishing trip. on the third day it quit running alltogather. i checked the spark and it had a very small amount on both coils but it was not consistant. so it set up for a while. i got my multimeter out today and tried to figure out what is wrong.
im an auto mechanic not a marine mechanic. but here is what i did.
i cut the wire going to the killswitch to the switchbox and it still wouldnt spark. i then checked the voltage of the wires to the coils from the switchbox, it was 0 volts. i checked and replaced all wires that were bare or old looking and still no fire. all my grounds apear to be good.
bare with me here, i dont know what these things are called...
under the flywheel there are 2 coils of which im guessing are the magnetos or generators, and a flat black thing with 2 wires going to the switchbox and 2 wires going into the coil looking things. i turned the key on in the running position but not starting and had 0.08 volts dc. i started cranking the engine and the voltage went up ranging between 11 and 15 volts. it was the same for both wires.
now im stumped and cant afford to go dumping money into this motor without knowing whats really wrong with it. can someone help me figure out what is wrong?
the part number on the switchbox is 114-4911 from cdi
serial # 4148481
