merc 200 sw 2004 hard start
grouper123
help .... mercury 200 salt water ,,motor will start and run just fine plenty of power nevever missis untill stoped or shut off for while .even just afew minutes ..will start right up then will stall and you got to prime builb i changed all lines hoses fuel separater fuel pump and fuel filters plugs drain carbs even changed picup tube from tank fresh fuel .still same problem never had this on other motors just started aboult 6 months ago motor has aboult 200 hrs .........anyone???????????
james williams
Re: merc 200 sw 2004 hard start
Good Friend,to save you some time,you might should move this to the Merc section.These old Johnson Gerus don`t know much about Mercs.
