merc 1972 165 barely runs after 1/2 hour
m keen
Hi guys, newbie here. have had a problem for the last couple of seasons with the engine slowly cutting back to a very rough idle after a hard run ( 1/2 hr to an hour @ 3000 rpm). have to limp back to port and sounds like th engine will barely stay running on slow rpm, very rough. could this be a distributor problem? on shorter runs there is not a problem and boat runs well. any suggestions would be appreciated.
Re: merc 1972 165 barely runs after 1/2 hour
Ayuh,... Welcome Aboard,... Is this 165hp, a 4 cylinder, or 6 cylinder,..??
m keen
anybody have any ideas?
a1nowell
m keen,
This is what happened with my 470:
In early April I was out for the first time this spring and after about 20-25 minutes of running just fine, my 470 started to run like crap. Nursed it back to the dock checked everything over, all good (new plugs & wires the previous week, Petronics ignition). The engine cooled down, fired right up and I went out again, in 20-25 minutes it started to miss something terrible. A friend suggested the coil, I went to NAPA and got a $14.00 universal 12v coil and installed it. Problem solved. I have probably been out 6-8 times since then, runs like a top.
Just my $0.02 worth,
Larry
cr2k
If the engine is not overheating, I agree it could be the coil. This is bad coil behavior. Changed fuel filter? Fuel pump problems?
fuel system seems to b good and new filter
Ayuh,.... "Seems" ain't quite tested, 'n confirmed....
There ain't no Easy Button,... You gotta fix it, it won't do it by itself...
m keen
yep. yr right. will grab a new coil as well just to b sure. thanks guys. will run it next weekend and let u know
