Butch Ammon
Thread starter- Joined
- Mar 26, 2004
- 249
Hello there... Happy Memorial Day!<br /><br />Today I was finally, FINALLY, FINALLY, able to take my old 17' trihull boat up to the lake. My wife was busy with stuff at the neighbors, and besides with my 19yr old twin daughters, one was working, so the other went with me.<br /><br />My old classic 1975 trihull has been started, de-winterized, etc... with a garden hose flusher and whatnot. Everything so far was okay and the boat would start up on the trailer with the garden hose and run fine.<br /><br />Today, my daughter and I launched at a marina and the boat was fine. We took off, trimmed it out, and proceeded down the lake at around 25mph. All gauges are okay, oil pressure, water temp, rpm's, etc.... We were cruising around and then slowed down when heading into narrow coves and so on. Still everything was fine.<br /><br />Then it happend... BOOM - nothing! It was just like an invisible ghost reached up and turned the key off. There was no noise, no grinding, no valve tapping or blown gasket sounds. No anything... Just -click-
The motor just konked out... Then for some reason the starter and/or start solenoid were acting up. You turn the key and you'd hear -click-. But yet you had lights, bildge, blower, horn, all power accessories.<br /><br />A guy stopped by and towed us to a nearby boat ramp/pier, to tie up the boat. Then while my daughter stayed with the boat, he gave me a boatride to the marina to get my truck/trailer and come back to this boat/ramp.<br /><br />So I figured, "Aw, the heck with it", and was just going to haul the boat back home. But for some reason, when I got back to my daughter at the boat ramp, I climbed back into the boat and turned the key to see if it would start. It was a totally different issue now. Instead of going "click" from the solenoid, it would turn over and the 165 IL6 would just go "Rrrrrrr", like it was trying to start but now it wouldn't catch and fire up.<br /><br />I'm extremely P.O'd now...
and my daughter didn't want to say a word because of my temper. She just helped me winch up the boat onto the trailer and hook everything back up, and we took off for home, totally discouraged.<br /><br />But yet, can someone explain this to me? Just about a 1/2 hour ago, I went out to the boat (now sitting on the trailer backed into my side yard), grabbed the garden hose and motor flusher. Just for kicks, I figured I try to start it or work on it or do something.... After cranking on the water, I hopped up into the boat and turned the key. Vrrrrrrrrooooooommmmmmm!!!! The boat fired right up and ran like a top!
Can someone kindly explain a cause of this? I don't want this post to get deleted or get banned or anything, so can I just use the wording.. WTF???<br /><br />This old 1975 trihull still has points, condensor, rotor, and all the old classics from '75. Were is the first place to begin to look as a reason for the boat to just suddenly konk out? Then go "click" at the starter solenoid? Could the ignition coil be going bad? I put new plugs and wires on at the end of last season, so they are still in excellent condition.<br /><br />Thanks for any help and suggestions...<br /><br />Butch A.
